Originally Posted by
flycatch
Thank you, for addressing my post however a jet turbine does have a combustion chamber which is evident in your pictures. This chamber does generate heat in a closed environment and the flash point for EPO foam is very low. How long would it take for the area subjected to this heat loose its structural integrity. Can it be measured that I can't say however the possibility does exist.
I'm not with you there. The hot exhausts are not in contact with the foam. Either you let them out behind the plane via a thurst tube or directly if the turbine are back mounted. Heat simply is not an issue. However a turbine makes ALOT of more power then the EDF setup. There fore not every foam plane are suited for turbine use. This Viperjet does fine though
