RCU Forums - View Single Post - pull-pull rudder cables
Old 09-26-2003 | 01:54 PM
DownSideUp's Avatar
DownSideUp
Default pull-pull rudder cables
I'm not a beginner, but asked this in beginners forum and got little interest. I have a Global Freestyle that requires a pull-pull cable on the rudder. The cables that came with the ARF got frayed and I couldn't use them. The only thing they had at the LHS was nylon. Is nylon inferior to cable? Also, the nylon always seemed to have slack, will this be the case with cable as well and is there a certain way you need to hook them up to make them work the best? Thanks in advance!
