Using MIX on 6EX transmiter
I am trying to use MIX 1 by mixing Channel 6 with channel 4. I have a separate servo on the nose wheel and want to mix it with the rudder with reduced rate on the nose wheel servo. I set up the mix with chan 4 as master, 6 as slave and plugged the nose wheel servo into chan 6. Well, when I give left rudder, the nose wheel servo responds properly but, when I give right rudder, there is very little if any movement of the nose wheel servo. i.e. it works properly for a left turn but does not respond to a right turn. What do I have to do to get it to respond in both directions? There does not appear to be any individual adjustment for both directions or, if there is, I have not been able to decipher the instructions properly. Thanks for any help in this problem. Rodney
