I am about to start my second Falcon 1.20 Ver 1 build. I stripped the film from one wing in preparation for sheeting and found the following.
The second rib in from the tip was a stick of balsa glued in with packing to support the cap strip. One cap strip was missing as well.
This one takes the cake,,, The drawstring provided to pull the aileron lead through to the wing root took a turn around a rib under the covering. Would have been rather frustrating.
This must be a Monday or a Friday built wing.
I shudder to think what I will discover when I pull the film off the other wing and the tail surfaces.
Col
