Crrc are famous for the soft crank case and the front and rear bearing spinning in the case it shows up with a lot of black gunk around the hall sensor area and in your exhaust. The best way to repair is to remove the bearing clean area's get some green lock tite and reinstall bearings make sure you use some small wire ties on all fittings as air leak in the fuel system will not draw fuel.
