Originally Posted by
Valve floater
No. Do I rich`in it? On the ground it has good RPM. I can`t get it to over heat on the ground. Turning 6600 on a 22-10 prop should be with`in spec`s?Not sure. Thanks
Drop a prop length 21-10 and up the RPM, engine will perform better at 7500 to 8500 RPM.
