Servo deflection at start-up
Hi guys.
Looking for advice here.... When I turn on the model, all servos deflect a bit, and stays there for a second or two before acquiring a signal from the RX. This has never bothered me before, but now I´m working on a model with retracts, where this is a huge problem, unless I´m willing to mount a new prop each time I turn on the radio. :-)
I´m using a Micro 12 powered by twin A123 unregulated packs. All firmware, in both TX module and RX, are newest edition (v2.63).
I seem to remember this issue being discussed a long time ago, and later updates should have solved this issue, but apparently this is not the case.
Is it only my gear that has this flaw, or is there a way around it if it´s common?
