Originally Posted by
nitrohead5300
The manufactor of the motor I own reccomends you use caster based 2 cycle oil to stay under warranty. I understand what you are saying go with the oil the manufactor of your motor reccomends. But I still wonder which is the best oil to go with. Have any of you guys out there who have used synthetic oil and had ring failure??
where do they reside...bleedin Bedrock? and i guess Barney and Fred work there too....
synthetics have their polymer chains altered to suit the needs of the given application, no mineral oil can come close to the lubrication/resistance to breakdown that synthetics give...while mineral oils are more than adequate synthetics are superior, some current syntheticss can be mixed as lean as 100:1...try doing that with a regular oil!
I've run belray synthetic since i was a lad in many different 2 stroke applications and never had ring failure
