Looks Good Vincent. I am wondering how you go about (especially on such thin stock) gluing down the sheeting. If this is described in one of the other build threads I will go look it up, but it seems I always have trouble getting a good tight fit to the ribs in these cases. 1/16 of a inch is too small to use "T" pins or something to hold the sheeting against a rib, is there a trick to getting the sheeting to lay up tight to the contour of the ribs?
thanks,
Dave
