Originally Posted by
speedracerntrixie
Hi Guys, I just scored a fair amount of 1/8" thick Nomex honeycomb, much more then I will be able to use. I can make up just about any composite panel with the stuff such as balsa, glass, CF or 1/64 ply. I was thinking that it's a great material to make bulkheads, battery trays, servo trays and such. I have used it in the past as tail sections on a few airplanes after bagging it between a couple sheets of 1/16 balsa. Question is, would there be any interest in honeycomb panels that can be fabricated with whatever skin you would want? Obviously prices would be dependent on the material used.
Shaun,
I think you may have a bit more response from the Jets jocks.
