RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 10-16-2013 | 10:21 PM
  #1511
Dave Wilshere
Originally Posted by husafreak
I noticed that one of the main gear air cylinders is sticking during a portion of its travel. I would like to fix it. I disassembled the main gear and removed the air cylinder. Then I unscrewed the square mounting block from one end and the air fitting from the other end. I was able to see into the open end of the cylinder bore on the shaft side and lubricate the piston with BVM air gear oil. But it is still sticking/moving roughly during the last 10mm of travel. Is it possible to remove the cap from the opposite end of the cylinder and remove the piston to inspect the bore and the 'O' ring? I have no idea what the piston is hanging up on but it is not smooth in that area. Maybe I can hand lap it smooth with very fine abrasive if I can find the imperfection.
This is sticking out of the wing too?
Check the rod more than the cylinder, there would have to be a big dent in the cylinder wall to restrict that. You sure its not mechanical on the slider? In the yoke too?
Dave
