The fuselage sides are cut out for where the firewall will mount and there is indeed rt thrust put into the firewall. Make sure you get the rt side and left side in the right positions. Not sure about the down thrust line though. I mounted mine without anything different then the way the kit is built and it flys great.
Jeff
