RCU Forums - View Single Post - Balsarite-Use ?
Old 10-19-2013 | 05:53 AM
  #35
greenjeep
I need to get some monokote to stick back down. I am having a problem with overlapped monokote peeling apart. What Balsarite formula are you using and are you using it like glue or applying it and ironing the covering back down?
TIA,
John
Originally Posted by jtotten
I have used balsarite for tacking down any film type covering that is starting to peel off the plane due to fuel soaking, improper film application at factory, or in repairing crash damage. I am currently trying in an old oil soaked model that I have removed as much oil as possible from by boiling, talcum immersion, "goof-off" application, and repeated applications/removal of lightweight spackle. I have heard that balsarite will hold down film even if the surface is a little oily.
