RCU Forums - View Single Post - 10G w/10 channel Rx...RCXEL kill switch...problem
Old 10-19-2013, 07:04 PM
Bob Paris
My Feedback: (13)
Ok Guys,
I still have an issue with the RCxl kill switch not working. I'm using a 10 channel Rx in my model.
I've set the RCxl kill switch into channel 8 on my Rx, and set up on my Tx on switch #28. The light goes on to indicate the engine is in run mode and the light goes off on my RCxl to indicate the engine is in the off or not run position.
I've set it at -100 & +100 per everyone's instructions...and my engine will not run with the light on or off. It should run with the light on, but does not fire up at all.
What am I doing wrong? Or do I have a bad RCxl kill switch?
Ok you Airtronic radio gurus...what's happening !
Soft Landings Always,
Bobby of Maui
