I did the same thing on a 4*60 I used to have. If the bulkheads are fine, I would cut out the damaged piece up to each bulkhead making a square patch. Cut out the patch to about 1/8" of overhang on each side and iron in place using matching covering. You could barely see it unless you were looking for it on the plane I did it on.
