Originally Posted by
Lnewqban
The adapter has been designed for a DLE30 and DLE50/55; hence, it may not match your four holes exactly or any step that goes inside the central hole.
The problem is that you will need to remove the hub retaining nut in order to verify that.
The instructions show that a regular deep socket will suffice for removing that nut.
It seems that the hub retaining nut of your engine is longer and a deep socket don't work.
Not being sure that the new assembly will work for your engine, I wouldn't cut in place and ruin the hub retaining nut, unless you have a spare.
I don't believe that a cut in place will damage your engine.
The lack of toother is just to make fabrication less expensive; I guess they trust the four holes to increase the grip on one side of a wood propeller, if compressed enough by the central nut.
Before ordering the adapter I made sure that the four-bolt pattern is the same between the DLE 30 and the RCGF 32. And I've got another approach for hollowing out the socket so I'll try that before I cut the prop shaft.
