RCU Forums - View Single Post - YS 115 problems
Thread: YS 115 problems
Old 10-22-2013 | 05:36 PM
flyitrite
Thanks wild for the help. The 3 turns out was on the low needle, I am trying to see where it usually is for most people. turning it out leans it as I understand. On the HS needle it seems to be around 1 1/4 to 1 1/2 turns. Never noticed an engine like this that will peak and does not do much for 5-7 clicks more lean. I did find an article from a Mike Hoffmeister that seemed to point this out. Also, I believe you may think this is the 110 because you mentioned a regulator adjustment which on this one ,( the 115 ), is fixed. Gonna run it again this weekend.
