Trailing link main gear is a must IMO.. Andy's short field takeoff technique is another good bit of info to go by. It helps reduce the roll out a good bit. Also make sure your brakes are fully releasing with them aired up. I know my eurosport brakes would stick if i didn't clean some of the crud out of them every few weeks. I also found a sticky brake valve to that would let about cause the brakes to drag a bit
