The razor has small wheels for grass and does not come off overly quick even on pavement. I think my old razor probably took about 500' on pavement to rotate. I doubt you could put trailing links in a razor, the gear is very short, I doubt I could put them in my Raptor which is bigger than my razor was. I had a pst1300 in mine too putting out 28lbs of thrust. The biggest issue with the raptor and razor for takeoff is the forward fuel tank is really forward and quite large so the jet is very nose heavy on takeoff.
