Originally Posted by
LGM Graphix
The razor has small wheels for grass and does not come off overly quick even on pavement. .......
Agreed. If you can install a bigger tire, it will help. I built a little T-45, that originally was a 90mm EDF. SO... the stock tires were tiny. (1.75") But, knowing I was flying it off the grass... I installed 3" mains, and 2.5" on the nose. It looks a little goofy, but it works.
And finally.... more thrust is always nice. (lol) Is this the ECU I turned up to 152K for you?
****EDIT****
One thing to remember... on the AMT's, they calibrate on every start up. SO... you need to hold the throttle to full, for at least 6 seconds, before your flight, for the ECU to give you full power. If you are just taxi'ng out, and hitting the throttle... you may only be at 90% power.
Doing a simple run-up may get you out of the grass faster with that engine.
(Do you have a manual? I can post one if you need it)
