RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 10-27-2013 | 04:09 AM
  #1532
izzy
Originally Posted by David J Ruskin
Hi Marty,
My Hawk when built looked great with twin pilot DerJet cockpit, smoke system, and Carf tube but……………it flew like a complete dog when below 40% throttle. Landings were pretty much uncontrolled crashes, and by some pretty competent pilots too! With just the UAT filled it weighed in at 39lbs! She had a remarkable tendency to nose into the floor at landing speeds…….ugh!
After stripping out cockpit, smoke set up and replacing the pipe with a lightweight Grumania one she now weighs 31 lbs and is transformed!! I can't really get the weight below that, but I know a couple of other Hawks in the UK are at 29lbs and they fly really well. Reducing the weight makes landings fear far easier, there is a much wider envelope of control. The C of G at the reduced weight is 195mm, and I solved the climb under power issue by moving the turbine above the rails.
Now I think I can enjoy the beast, they do look great in the air!!
Cheers
David
David -
i am in the middle of a build and need to paint her so am going to bve very careful with paint so as not to get her "plumped up "
Dave - is this the dry weight that is normal ?
thanks izzy
