Back on track. I now have the nut plates properly secured.
Those 2 little nut plates in back cam out with very little effort. I used a hot exacto blade to cut the epoxy. I think I spent at tops 30 minutes removing them.
I then made one nut plate and epoxied it into the back section.
I did the front right from the beginning, so no problem.
I then ran the servo screws into the nut plates, 4 each. They are counter sunk and will be puttied over.
I think the nut plates are now up to the task.
I think at this point I will jig it to my building board . One to get the stab slot trued and primarlily to get the wing struts built and the top wing aligned.
Ken
