Originally Posted by
Instructor
Skidman,
I don't mean after the link-up has been established, I mean the first time you turn on the transmitter and then the receiver. Try it and you will see what I mean. The Futaba 2.4 links up much faster than the Spektrum. I know, I have tried it....
Larry
You said that the (up to) four seconds longer made a difference to you since you flew turbine aircraft. I assume that it must feel like a significant difference if you bring it up.
Instructor
When I fly my turbine powered plane and that time span is 4 seconds longer, it makes a difference to me.
Since the longer delay only takes place during the first power up of an aircraft, why would that make a significant difference to you? The only way it made sense to me was my assumption that you thought it took a similar amount of time to relink if for some reason communication was lost.
Paul
