RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 10-30-2013 | 12:59 AM
  #1544
fireblade5437's Avatar
fireblade5437
Just going back to when weights were being discussed, I had a chance to weigh my Hawk and after having painted the fuz and tail plane and wing as original (but will be painted). Now this does have Der jet cockpit with one pilot, my light set with 4.7 Li-Ion etc and it weighs just under 29.4lbs so for all the 2k primer and paint pretty happy with this weight probably around 300g for wing when painted as estimate
Also has any one got advise on how to paint over the live hinge as masking the thin line would not be easy unless using PCB track tape, never have painted over a live hinge! Noticed on ailerons and flap there looks like 0.5mm gap....don't fancy running a blade down the line after painting for obvious reasons!
One way way is to mask and spray either side of hinge line separately?
Alan
really have to watch the spell/grammar on this iPad it has a nasty habit of changing text without you noticing!
