RCU Forums - View Single Post - Evolution 10cc engine - Tank Setup
Old 10-30-2013 | 03:56 AM
flyinwalenda's Avatar
flyinwalenda
Also make sure you are using a gasoline stopper and lines(black neoprene or yellow Tygon) inside and outside the tank and put a filtered or sintered clunk on the pick-up line . Check the muffler and if it hasn't been sealed, take it apart and reassemble using high temperature engine sealant around the joints and on the rod/bolts.
