Originally Posted by
cap3Der
Thank you for numbers mattnew. The build looks really good. I've got Dle 50 already, but I can see how it would probably be too big for this aircraft, thanks to your pictures I've got some idea about its dimensions. I also got glow OS 120AX, will this engine be too small for this Decathlon, provided that I'm going to take my chance and not do a "laminated" tail feathers, and lets say use cable pull-pull system on both Rudder and Elevator?
Well, if you already have the DLE50... :-)
Here is a review from Dynaflite's site
http://www.dynaflite.com/reviews/gpma0510-rce.html
"Dynaflite recommends engines sizes from 1.08 to 1.80 2-stroke, 1.20 to 1.60 4-stroke, and 1.5 to 2.1 gas. The instructions provide firewall details to install an O.S. 1.20 and the U.S. Engines 25 cc power plants. Installation of servos, battery, etc. is designed mid-way back in the fuselage tail section to offset the weight of the larger engines."
so your 120AX is right in the middle of the range of glow engines. The largest gas engine they recommend is 35cc ( 2.1ci ). I think the 120AX wouldn't be a bad choice, though it probably wouldn't give you unlimited vertical. It all depends on what you want....
