RCU Forums - View Single Post - Airflow visualisation
Old 10-31-2013 | 08:23 AM
  #113
mithrandir's Avatar
mithrandir
in a vertical upline... the downwash ought to be very close to 0 (Zero)
though there is a wake.....
IMHO, CG is not the best way to deal with Yaw-Pitch coupling....
Moving the CG fwd will result in a Hz Tail or decalage trim to compensate... this
will prolly have negative impacts elsewhere.. such as the upline you just fixed....
I have also speculated that adding additional vertical area to the underside of the fuselage (Subfin)
could influence the yaw-pitch coupling.... Perhaps that will be a future investigation of the simulation
I am doing as shown below???
