Originally Posted by
cap3Der
Thank you for numbers mattnew. The build looks really good. I've got Dle 50 already, but I can see how it would probably be too big for this aircraft, thanks to your pictures I've got some idea about its dimensions. I also got glow OS 120AX, will this engine be too small for this Decathlon, provided that I'm going to take my chance and not do a "laminated" tail feathers, and lets say use cable pull-pull system on both Rudder and Elevator?
I would say the 120 would be a better choice than the DLE50. It would be a lighter engine and not require as much additional weight to balance. If you go with the DLE, I would do some serious reinforcing of the firewall.
