Yes I saw on the other forum you were sorted so I didn't persue it. What is it you need to know? Mine is the Sierra one mounted horizontally, It is controlled by a JR 8511 mounted on the keel at the back of the cockpit through closed loop. I have four strands of 80lb nylon, I found this to be about right just enough streach so as not to strip the servo gears and tought enough for control. It was an expensive lesson.
Mine is hydraulically operated and to get the proper scale effect it should retract off the door circuit not the main gear circuit. (I know it’s a bit anal but you might as well have it right).
m
Don't know weather you have seen this video, taken at the Baldock large model do.
http://youtu.be/UQuEGy57j8M
