Thanks Flywilly.
I will reduce the throws mechanically, but as I stated, the main problem is that it just continues to roll to either side as soon as it starts banking. That is, if I set at 30º it will continue to roll ON ITS OWN until it is close 90º. Thats to either side. I also setup aileron low rate to 60% AND -50% Expo The responsiveness was reduced but the situation mentioned above was not.
