RCU Forums - View Single Post - Small gearbox sources.
Thread
11-03-2013, 05:54 AM
7
ausf
Here's the exact motor:
http://www.robotmarketplace.com/prod...OPAL50-SH.html
Voltage:
4.8-14.8V
Output Speed:
300rpm @ 12V
150rpm @ 6V
Stall Torque:
58.9 oz-in (4241 g-cm) @ 12V
48.43 oz-in (3487 g-cm) @ 6V
Size:
1.46" (32.2 mm) long, 5/8" (16mm) diameter
Weight:
0.8oz (22.7g)
Gear Ratio:
Metal Spur gear 50:1
Stall Current:
Stall at 1.5a
Shaft Info:
4mm diameter with 2 flats; 9.5mm long
These are pretty high
torque set ups designed for robotics, I don't think you'd have an issue with a tank that's small enough to consider these. They fit side by sside in the 1/16 38T hull, which is pretty tight.
Reply
Like
ausf
View Public Profile
Send a private message to ausf
Visit ausf's homepage!
Find More Posts by ausf
View iTrader Profile
