RCU Forums - View Single Post - Did they stop making Ambroid glue?
Old 11-04-2013 | 02:26 AM
  #37
chuckk2
I've tried several glues that are not the same as the old glues.
CR can give mixed results
The various "rubber" cements have all the classic problems
The commonly available wood glues work well for furniture, but not that great for models.
So far other than CR and epoxy I've added two glues to my gotta haves.
UHU POR is a good canopy glue, and also very useful for temporary use in sticking things together (Trial, alignment, etc.) Can be hard to find, and is often out of stock.
A glue from the craft hobby area, E6000 is similar to UHU POR, but has more bonding strength, and gives a stiffer joint.
It seems to do well when structural considerations are involved.
"Hot Glues" don't seem to have as good a bond as the more conventional glues, although the higher temperature type works a bit better.
As to Epoxy, I've had some short working time problems with some of the popular "30 minute" ones.
