Jeremy looks like you made some foam dust there... WOW that thing is sleek as hell ! Since you are doing the laminated construction - maybe take a trick from the surfboard guys and put a piece of thin plywood in between near the deck layer - to stiffen it slightly - but also to mount your servos, motor mount blocking,and stuff... that is a sweet looking hull and when fully glassed should be plenty strong.
