RCU Forums - View Single Post - Servo leads interference
Old 09-27-2003 | 12:13 PM
GalenB
My Feedback: (18)
Default RE: Servo leads interference
I do not think you will need anything special for this setup. I would simply do a thorough range check with the engine running and not running before flying. If the range check is good then fly. I have extensions this long, or longer, in my 29% Edge with a Brison 3.2 and have not had a problem. My extensions do not have a plug and are put together using solder connections...
