Carlos not sure with other UAT's but if you fill the CAT via the fill barb any dirt will potentially end up in the tank as you correctly say, however when the fuel is drawn out of the tank assuming the dirt comes with it which it will with either a felt filter, paper filter or no filter it will be stopped at the filter in the CAT before it goes to the pump.
marcs
