Yep... what Marc said.
If you use a felt clunk... you should fill the tank from a vent hose. (like when using a UAT) That way... the dirt will be outside the felt, and it will work as a pre-filter. If you fill thought it... then the dirt gets trapped, and then goes into the fuel system when started.
