In an attempt to keep my ESM cat as light as possible I am contemplating using carbon push rods with elev. servos mounted farther forward rather than install them in the tail as the plans call for. As I indicated I will be using DLE 20 RAs. How much weight, if any at all, did those of you that are flying them now have to put in the nose for balance? Did you install the elev. servos forward in the fuse or in the stabilizer? Thanks.
