Now I mixed up some 30 minute epoxy and prepared to glue the stab assembly onto the fuselage. I made sure that the reference line on the stab was lined up with the back end of the fuselage and then used a tape measure and a straight pin stuck into F3 at the reference line to measure from the centerline on F3 to each stab tip. Made one final measurement of the horizontal stab alignment on either side with a ruler so that each tip is an equal distance from the table top. Time for a break.
