RCU Forums - View Single Post - Servo Control Arm Position
Old 11-09-2013 | 10:25 AM
Lnewqban's Avatar
Lnewqban
Originally Posted by KW_Counter
Is there any reason why I can't mount it parallel?
I see no problem for throttle servos.
The torque reaction (shear force on the anchors) is the same, however, the force trying to pull the anchor is as many times higher as many times the distance between the anchors is smaller.
For servos under some important load, you could eliminate that anchor over-stressing by building some (wood) support around the lower body of the servo.
