Well, here she is, almost built.
I have just a couple of small things to do before covering. The tail skid mount will be reinforced. I think VG mentioned it tends to break. The throttle servo mount needs to be built. Sometimes I'm a bit of a dummy, and on this occasion it took me a while to realize that the throttle arm on the carb could be rotated to make servo mounting easier.
Additionally, I ended up with a gab between the firewall and the top center fuse section which will have to be closed up. Gluing some balsa in place and sanding will do the job.
And, of course, there are the assorted hangar rashes and blemishes that have to be fixed, but I'm pretty much ready to sand everything nice and smooth then cover.
