As I noted the servos with only two mount screws ' Not Four' screws a sideways mount on throttle is an exceedingly bad idea, been there done that, several times an each time it was necessary to go back and remount longditudinally. On a flight surface an sideways mount a 'two screw' servo could even be dangerous because of the rocking which will get worse with use.
John
