Originally Posted by
R32GolfTA06
I guess that makes sense mounting it on the right side then. Which low pro do you have? You did say previously a little flex is good so unusual you big up the r sector so much as it's a contradiction from what you said before
Damn! This is the fourth try at posting!
This site must still be having periodic troubles... I'm going to see if this one posts......
I use the Spektrum S6070 exclusively. The Savox SC1251 is the same, internally, and both go for around $60 US. They are both fast (.9 transit speed) and both are metal geared.
Yes, I did mention flex is beneficial for drift, and that won't change. I also mentioned previously, that a stiff chassis will require more precise adjustments, which is also why I don't recommend the IFS, because it is not as precise to adjust, as a standard stand up shock tower arrangement. The thing about stiff chassis is, you can easily see what and how adjustments do, and work.
It's all a learning experience!
