RCU Forums - View Single Post - Brison 5.8 problems
Old 11-13-2013 | 07:40 AM
ron a norman
My Feedback: (14)
Pull the carb off, there should be a small hole that passes through the insulator block ( about 1/8" ) this is the crankcase pressure port make sure the gaskets on both sides of the block do not block this port. Make sure that the hole lines up with the hole in the carb and the hole in the crank case.
