RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 11-13-2013 | 11:13 AM
  #1628
fireblade5437's Avatar
fireblade5437
Izzy
I know pic bad but all I can do at moment, I used 2 or 3mm fibreglass board (cannot remember thickness) but I used Hysol glue to glue two nuts on back on board then bolted ram bracket to the fibreglass board then using Hysol glued the whole assembly into position. Once dry I just use a Allen key to remove the bolts leaving plate and nuts in place, this makes it easy to fit the bolts back in when re-fitting ram assembly. You can only see one cap head in picture but you get the idea!
2nd pic shows the door assembly which is ran with small Hitec MG thin wing servo, there is a pic of this way back in thread that shows it clearer.
Most of work probably about 99% of what I have done is on the thread and of course all the other guys have posted pics of what they have done as well. Might be a good idea to spend a evening going through the pics
Alan
Originally Posted by izzy
Can anyone show me how they mounted the air rams for the front gear so that they are removable I case needed
i have chosen the 2 door option
thanks
ID:	1938989   Click image for larger version
