Originally Posted by
JGFAN4EVER1
As your looking from the front of engine with cylinder facing downward its on the right side of the motor in the crank case, right now its open. There are no extra nipples or anything on the carb, its a walbro sdc 80 carb. Should the plug on the side of the engine be capped off?
When plugging the hole on the side of the crankcase use a bolt that is only long enough to penetrate the case or at least be sure there will be no interference with internal parts when the bolt is seated . If the engine has been sitting for several months the diaghrams in the carb get stiff and the needle can get stuck seated as well . I would go ahead and install a carb kit in that SDC 80 carb . BTW sure to get the correct kit for an SDC 80 (K10 SDC)
