RCU Forums - View Single Post - Model name confusion
Old 11-14-2013 | 07:59 AM
Bax
When you go into the Model Setup screen, and then the Model Management function, you are able to set the name of the model. After you have entered the name, you just press the "ESC" button to exit. The model name should show up in the upper, left-hand corner of the main screen, next to the number of the memory slot the model info is stored in. If you enter the model name, press "ESC" and the name is not saved, then your transmitter has an internal problem storing the model name, and it should be sent in to the service center.
