RCU Forums - View Single Post - Nitro buggy idle problem??
Old 11-17-2013 | 05:30 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
When the idle slows down and slowly gets lower and lower until the engine quits means the idle mixture is lean. Opening the idle gap makes the idle mixture richer but likely requires a few adjustments to get the slide gap and idle mixture right. If blipping the throttle a little bit makes it recover, then the idle mix is lean for sure.
