RCU Forums - View Single Post - NovaRossi Engine Testbed
Old 11-17-2013 | 10:54 AM
  #51
Dave Harmon
Originally Posted by doxilia
Keith,
My goal is for it to be ready to fly at 7.5 lbs with an additional pound of fuel for an 8.5 lb model on takeoff.
David
David.....I made some experiments some time ago and determined that glow fuel weighs about 1oz per liquid oz.
If you are allowing 1 lb for fuel....you'll have about 16oz of liquid weight.
You could likely plan for 12oz standard fuel and save a 1/4 lb or more while you are at it.
The reduced nitro (10%) used with the NR will remove half the nitro weight. The oil content will have an effect on the weight too.
You can weigh 1oz of the fuel you intend to use in a 1oz mixing cup and get a grip on it.
Before the 89' NATS in Washington State....I was using the YS RE ss and was running out of fuel on the next to last manouver.
I could not get a larger tank in the airplane (Suprafly) so I mixed my own fuel....13% total oil (8 castor/5 KLOTZ) 20% nitro 2% propolyne oxide.
This mix actually gave quite a bit more RPM than standard 18/20 fuel due to the much reduced oil drag.
The castor kept the engine happy without gumming up the works...and at the NATS I was landing with about 2 oz reserve.
I had to do this to gain more endurance...it's all about considerably reducing the viscosity of the fuel to allow the needle to be closed....less fuel through the engine....
How can you gain RPM with less fuel flow???
Reduced oil drag.
Works great.
Dave
