Not testing anything here as you aren't letting the circuit build the voltage necessary to spark with your connection set up. Hook the jumper you are using to form the airgap to the ground lead from your ibec vice the shield wire and see if that causes a problem. Bet something cooks. A stray spark is going to jump to ground not the positive lead coming in. Is there any suppression on the ground side? High voltage can do strange things...
