yankphan,
Will send through lots of build pictures to your email... The stock wooden blocks get glued in and i think they will need to be removed to fit retracts for sure. If you do fit the standard stock landing gear i would recomend the main blocks be reinforced, the small block on top of the base mine came apart on ground testing just befor the maiden both sides and had to glue them in at the field they had very little glue from the factory...
